Re: Farmall M Transmission pilot bearing
Posted by John M on November 19, 2005 at 05:20:38 from (64.53.75.223):
In Reply to: Farmall M Transmission pilot bearing posted by gussie on November 18, 2005 at 11:46:50:
Im trying to remember this so bear with me. The needle bearing on the main shaft is held on with the bolt and washer, this bearing rides inside the constant mesh gear.(I called it that, but there is a technical term for it, maybe main drive gear. This gear drives the bottom shaft)There is another bearing in the housing for the constant mesh gear that that shaft rides on which is the one the snap ring holds in place with the snap ring.The drive side of the coupler goes on the end with a bolt and washer as well.Ill assume you have the constant mesh gear out, so I would go aheaad and replce the bearing and seal while you have the pump dropped.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
