Re: 434 starting problem update
Posted by John T on November 19, 2005 at 13:51:22 from (66.244.90.98):
In Reply to: 434 starting problem update posted by AL Sproule on November 19, 2005 at 11:18:25:
Al, I dont know beans about any 434, so go with what Old or ElToro says over me, but heres my generic thoughts which may help or may hurt lol NO WARRANTY EXPRESS OR IMPLIED. On many key type spring start switches, the terminals are like BAT for the hot voltage input from the ammeter or voltage regulator etc.,,,,,,,,IGN which powers up an ignition coil on gas engines whe the keys in the ON position,,,,,,,maybe an ACC terminal for accessories when key turned backwards,,,,, and often one thats unlabelded or by itself etc is what powers up the starter solenoids lil S activation terminal when the key is in the Start position. See if the solenoid has a lil S activation terminal??? If so its what requires voltage to engage the solenoid, and if you hot wire jump it from a hot battery cable it will engage. Thennnnnnnnn its gotta be connected to whatever terminal on the switch thats HOT ONLY WHEN IN START POSITION. Use a test lamp to insure the switch indeed has a hot voltage feed to its BAT input terminal. That would be fed like off an ammeter or the BAT terminal on a Voltage Regulator etc, somethign thats ALWAYS HOT. Then put the lamp on the switches lil terminals to find which one is hot ONLY when in the start position, and wire it to tHe solenoids lil S activation terminal. NOTE this assumes the solenoid really has a lil activation terminal (usually labeled S) and the solenoid works?????? I say that cuz when you mentioned you jumped it at the solenoid, Im not sure if you jumped voltage to the lil S terminal or you jumped around the solenid to crank the motor??????? Most solenoids are case grounded, meaning their frame or mounting screws require a frame ground IN WHICH CASE IT WONT WORK IF NOT GROUNDED. See if the solenoid is grounded or needs a ground wire etc. CUZ IF NO GROUND SHE WONT WORK REGARDLESS WHAT YOU WIRE TO IT !!! Thats all I have to say about that John T
Home
| Forums
Today's Featured Article -
History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
