Re: 706 Injection pump ?
Posted by IH doc on November 19, 2005 at 19:33:10 from (207.190.77.97):
In Reply to: 706 Injection pump ? posted by stu in njo on November 17, 2005 at 12:56:06:
First off, does your tractor have glow plugs? If so you don,t have a 310 german engine, you have a D282 engine which has a roosamaster pump. Yes the seals on the injection pump drive shaft are probly leaking.If you put a pump on this tractor before you should have changed the two seal on the drive shaft then.they are kinda hard to get started inside the pump when reinstalling the pump but can be done with out any special tools.
Good luck & hope thing go well
if
Post a Followup
