Re: having trouble putting chains on my tires 11.2
Posted by Mike Van on November 20, 2005 at 03:16:11 from (24.151.104.209):
In Reply to: having trouble putting chains on my tires 11.2-38 posted by lekander883 on November 19, 2005 at 20:03:39:
Most truck chains have just a hook on one side, easier to get between the duals. Tractors usually have 2 latches. It will work though - Put the hook on the inside, if you have to, wire the outside & drive back & forth a hundred feet or so. Stop so the wire is down and try to get the latch caught. Some skidder guys use a chain binder to suck the slack out. If you can't get it, they are too small, they need a few inches of chain added to the sides [both to keep them even.
Post a Followup
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
