Re: Farmall not firing
Posted by Hugh MacKay on November 20, 2005 at 13:52:55 from (209.226.106.71):
In Reply to: Farmall not firing posted by railroadgoat on November 20, 2005 at 12:52:42:
How tight or loose is the distributor shaft. Years ago my Super A commenced stopping when hit a bump. In the early stages it would always fire right up again. This problem progressed until it wouldn't fire up. Turned out distributor shaft was loose. That loose shaft destroyed a lot of rotors and caps in the process. I had CaseIH rebuild it for me, they farmed it out to a machine shop, that was doing these quite regularly for them. I have not had a bit of problem in roughly 12 years since doing that, in fact I think the same cap and rotor are there that I put on tractor back then.
Post a Followup
