Re: Farmall not firing
Posted by railroadgoat on November 20, 2005 at 14:54:12 from (209.247.222.40):
In Reply to: Farmall not firing posted by railroadgoat on November 20, 2005 at 12:52:42:
With the switch on, or with a wire from battery to coil, I get fire out coil wire, BUT not a good blue spark. Don't have time to try the condensor wire off as I need to go to work. Will try this Tuesday when I get home. If it doesn't drive me nuts first. Thanks
Post a Followup
