Re: Lift-all high pressure belly pump `
Posted by Dave in CT on November 20, 2005 at 17:54:49 from (69.182.78.3):
In Reply to: Lift-all high pressure belly pump posted by Randy-IA on November 20, 2005 at 16:12:33:
Yep, went from 500 to 800 PSI. An improvement package (15261-E) was made available to convert the lower pressure units to the higher pressure units. Most lift-alls you find are of the 800 PSI variety. Originally, the high-pressure units had a yellow '8' painted on the outside of the reservoir. For prices, check the usual suppliers - I tend to go with Steel Wheel Ranch - www.steelwheelranch.com. I rebuilt one a few years ago - replaced everything but the drive gear seal and the parts came to about $30. It's not a very involved procedure.
Post a Followup
