Re: Farmall not firing
Posted by John T on November 20, 2005 at 18:23:51 from (66.244.90.98):
In Reply to: Re: Farmall not firing posted by El Toro on November 20, 2005 at 15:14:33:
Hal, darn good point you bring up. Im just too used to JD's when the distributor is in time or 180 out, but your point reflects the concern I had about the wrong distributor cap or it not in register, which yields the same effect of an out of time distributor whereby his rotor tip isnt lined up with an internal pick up to the correct plug at the correct time!!!!!!!!!
Is his distributor pure gear driven which has to be at the right tooth on the cam etc or is it a cog type drive thats either right or not period?? I take it its a gear from what you say and since many are.
John T
Post a Followup
