Re: Farmall A / Zenith Carb choke
Posted by Karl Hamson on November 21, 2005 at 12:56:28 from (139.142.99.29):
In Reply to: Farmall A / Zenith Carb choke posted by Kendog on November 21, 2005 at 12:41:49:
I am not sure my carb is a Zenith but the rod pulls to close the choke butterfly. Same on the C
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
