Re: Farmall A / Zenith Carb choke
Posted by Pharmall on November 21, 2005 at 17:16:16 from (68.9.106.167):
In Reply to: Re: Farmall A / Zenith Carb choke posted by Kendog on November 21, 2005 at 17:05:24:
The choke lever on the Zenith carb on my '48 C points down and
to the front when the choke is open, and down and to the rear
when the choke is closed. Full open to full close looks to be
about 90 degrees of rotation.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
