Re: 766 remote hydraulics slow
Posted by Weldon on November 21, 2005 at 17:24:34 from (151.213.99.211):
In Reply to: 766 remote hydraulics slow posted by RM on November 21, 2005 at 11:42:36:
How about the three point lift? Will it lift a heavy load satisfactorily at low speeds or only at middle to high engine speed like the remotes?With a new pump, clean fluid and filter , system should have a test pressure of 1900-2100 psi according to I&T shop manual. If pressure is not as stated, renew relief valve which is available only as a unit.
With both pumps whining a little, could be sucking air somewhere in suction lines to pumps. perhaps someone else can elaborate on this.
Post a Followup
