Re: Which 12 Volt Alternator?
Posted by John T on November 21, 2005 at 19:15:25 from (66.244.90.98):
In Reply to: Which 12 Volt Alternator? posted by Tweeter on November 21, 2005 at 18:59:03:
Tweeter, myself and a lot of people use the GM 10 SI 12 volt Negative Ground Alternator as they are so cheap n readily available, however, they are a 3 wire internally regulated but its so easy to excite them n make em function as a one wire they are often used. They make true One Wire alternators which are easier to wire, just take the output n get it to the battery often via the ammeters load terminal, but they dont kick in until a tad higher RPM and may cause a very slight battery drain when setting I believe.
John T
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
