Re: Which 12 Volt Alternator?
Posted by Bus Driver on November 22, 2005 at 04:47:31 from (66.226.35.93):
In Reply to: Which 12 Volt Alternator? posted by Tweeter on November 21, 2005 at 18:59:03:
The Delco 10si used on regular vehicles is at least 37 amps and often goes up to 63 or so. A 37 will be more than adequate for your tractor. The rating will be stamped on the alternator. If space is tight, do not use one from a Chevelle. The base mounting holes on it are farther from the body than on the typical 10si.
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
