Re: Trouble Starting (49-M)
Posted by old on November 22, 2005 at 07:17:19 from (207.69.138.143):
In Reply to: Trouble Starting (49-M) posted by fisherman on November 22, 2005 at 07:04:57:
I'd pull the starter and do a bench test just to make sure its not another problem. It could also be a stuck starter drive in the flywheel which would also cause that problem. Pulling the starter would fix the stuck drive. Also fix the battery cable ends because that is part of what cause the starter drive problems. Clean,tite, and bright with all wires is a rule of tumb.
Post a Followup
