Re: H rear axle removal
Posted by Nebraska Kirk on November 22, 2005 at 17:52:35 from (207.91.30.14):
In Reply to: H rear axle removal posted by Ed Harper on November 22, 2005 at 17:30:28:
First you will have to remove the bolt that holds the bull gear on the axle. This can be done by removing the PTO and then reaching through the hole. Next you should remove the wheel. If you have a hoist you can leave the hub attached, otherwise you should remove it too. Then unbolt the rear axle carrier cap, and then the axle will slide right out.
Post a Followup
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
