Re: Trouble starting.
Posted by John T on November 23, 2005 at 17:40:56 from (66.244.90.98):
In Reply to: Trouble starting. posted by Fisherman on November 23, 2005 at 14:44:30:
Fisherman, just because its Positive ground, that dont determine whether its 6 or 12 volts, most old tractors, 6 or 12 volt, still used Positive grounding.
Also, the genny will work at EITHER ground so long as its Polarized.
If it had a 12 volt battery in it, I would suspect it may well be a 12 volt genny, I guess you cant find any labels on the genny or Voltage Regulator??
You asked about not frying something, you may wanna see if you can determine if you have a 6 or 12 volt coil and if theres any external Ballast Resistor in the ignition circuit wired ahead of the coil?? If its a 12 volt coil or you find an external ignition Ballast Resistor, thats a darn good indication she was converted to 12 volts, although it still dont tell ya if they changed the genny. If you put 12 volts on a 6 volt coil without the ballast, the coil will run very HOT and the points will burn up quicker, so that may be one of the dangers you need to look into. Other then 6 volt lights would burn up on 12 volts and possibly damaging a Voltage Regulator, youre probably not gonna do much more harm if you connect 12 volts on a pure 6 volt system.
A 6 volt coil would read around 1.25 to 2 ohms or so between its lil + and - terminals while a 12 volt internally ballasted coil will read more like 2.5 to 3 and over if you have an ohmmeter handy.
Let us know how things turn out
John T
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
