Re: Farmall A replacement engine?
Posted by Hugh MacKay on November 24, 2005 at 02:13:44 from (216.208.58.104):
In Reply to: Farmall A replacement engine? posted by BigManOnCub on November 23, 2005 at 18:51:58:
The basic block supposedly never changed from 1939 until end of C production All Super C from beginning and Super A after serial number 310300 have the new C-123 block. So that should include all A, B, C and SA before serial 310300.
However you should be aware the block part number did change a few times even in that group, may not make any difference but as old said there are different part numbers, so something must be different. Even if you find a block with same part number as yours, you still have to check out the fact someone may have done a rebore, to acomodate oversize sleeves.
Safest bet is take the old block when shopping, make sure it is exactly the same.
Post a Followup
