Re: Leaking oil pan
Posted by El Toro on November 25, 2005 at 18:29:54 from (64.12.117.13):
In Reply to: Leaking oil pan posted by GordoSD on November 25, 2005 at 17:14:57:
Try a flat copper washer on the bolt. They're used on flex brake lines that are connected to the brake caliphers. Once in a while you get a leak. Usually can be corrected by running the washer over a flat file or replacing the washer.
Hal
Post a Followup
