Re: Magneto timing
Posted by Bob M on April 08, 2009 at 10:34:55 from (151.190.254.108):
In Reply to: Re: Magneto timing posted by ScottyHOMEy on April 08, 2009 at 10:13:50:
Scotty - According to my data sheet the stock B distributor runs even MORE advance than the mag (40 deg vs 35)
Would then logically expect that running a B on a mag with only 15 deg advance would sacrifice performance at speed. (It might idle a little better however...)
Besides it would tough to adapt a diesel mag since diesel mags turn the opposite direction from the gassers.
