Re: 450 leaking hyd somewhere
Posted by Hugh MacKay on November 26, 2005 at 15:11:45 from (216.208.58.160):
In Reply to: 450 leaking hyd somewhere posted by Mylesa on November 25, 2005 at 16:42:05:
Mylsa: The 450 can not leak oil from transmission to engine or vice versa. You can get leakage as Hal suggests from hydraulic system into the crankcase, via the shaft that drives the pump.
From your description I suspect not only is pump leaking into crankcase, but it is in poor shape as well. Probably the best cure would be a rebuilt or new pump. If you have no external leaks this should cure the problem. Shop around on that pump, there are several sources. I would talk to CaseIH first.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
