Re: 1939 m farmall
Posted by DWV on November 27, 2005 at 12:45:45 from (152.163.101.13):
In Reply to: Re: 1939 m farmall posted by farmallguy3 on November 27, 2005 at 08:52:37:
Yes it makes the PTO 2 speed also but thats just a side effect of making the transmission dual range.The 2 pins have a splined piece on front end and under front 2 gears on that shaft.It has splines on inside and outside.One side to turn trans shaft and other to lock in whichever range gear its shifted into.I think it is a M&W 9 speed from what you described.
