Re: C with hydraulics ?
Posted by El Toro on November 27, 2005 at 15:38:17 from (152.163.101.13):
In Reply to: Re: C with hydraulics ? posted by Kevin Hood on November 27, 2005 at 14:27:39:
The Super A's started with the C-113 engine in 1947 used that block up to SN 310299. Starting with SN 310300 to 356001 they had the C-123 block with thick sleeves, I think the cid was still C-113. The first of these were made in 1951. Then after SN 356001 they boosted the bore to have the C-123 engine in their tractors in 1954. This engine also came with the water pump installed.
You could retrofit the other tractors too, that had the C-123 block with a water pump. Hope I got all that right. Hal
