Re: M Serial Number Tag Info
Posted by CNKS on November 27, 2005 at 17:13:41 from (204.249.178.138):
In Reply to: M Serial Number Tag Info posted by Robert in Granbury on November 27, 2005 at 15:07:24:
The chassis serial and the engine serial are not the same -- if you do that then there could be two M's with serial #FBK 71667. The prefix FBKM is used only for the engine, the chassis prefix is FBK.
