Re: More red hot resistor -again alannpa
Posted by Janicholson on November 27, 2005 at 18:23:27 from (66.173.50.39):
I don"t know the specification for resistance on the field, but it should be the same (within a few tenths of an Ohm) of other same voltage Farmall Generators. If it is not, then rebuilding the field might be in order.
Disconnecting the field terminal from the gen. then starting it, should keep the resistor from getting hot. If it does not then there are wiring problems.
Keep this going till the problem is fixed, or let us know the outcome.
JimN
