Re: Fuel Shut-off
Posted by Haas on November 27, 2005 at 18:44:48 from (12.65.78.243):
In Reply to: Fuel Shut-off posted by DelMN on November 27, 2005 at 13:28:24:
Leave the sediment bowl and install a filter in the line between the sediment bowl and the carb. NAPA can supply both a filter and a shut off valve if you want a shut off in addition to the sediment bowl valve. I have two tractors that have quarter turn plastic valves from NAPA. One of them still has the sediment bowl, the other just a filter. The tractor was like that when I got it. 3/8 rubber gas line tubing works well with them.
