Re: Super A or C engine casting number
Posted by Stan(VA). on November 28, 2005 at 08:16:24 from (66.82.9.25):
In Reply to: Super A or C engine casting number posted by Gary Hunter on November 28, 2005 at 08:00:21:
The 366204 is a replacement block in the C, it was either swapped out of a 130/230 or was a dealer replacement. It will fit your Super A as is; but if you are buying it stripped, the internals (sleeves) would only fit if you have the early 251069 block and not the late 354898 in your tractor now.
Stan(VA).
