Re: 8v Follow up.....
Posted by John T on November 28, 2005 at 12:08:29 from (66.244.90.98):
In Reply to: Re: 8v Follow up..... posted by JT on November 28, 2005 at 11:22:20:
Hey JT, Im NOT here to argue either just to try n help people the best we can. I agree definitely a Mag retards the timing when youre starting her, otherwise when shes slow cranking she would fire like 20 degrees Before TDC causing her to kick the flywheel backwardsssssss and thats a definite NO NO. Butttttttt then when the wind n trip assembly stops functioning (centrifugal force prevents dogs from engaging) the run time advance takes over which allows them to fire maybe 15 to 25 degrees (depends on adjustment) Before TDC as needed, and the rotor is turning at straight speed same as the driver NO WIND UP N TRIPPING OF A SPRING THEN LIKE AT SLOW RPM HOWEVERRRRRRRRR (Rememeber Im more familiar with JD Mags like the Wico C and X or AP NOTTTTTT the Farmall Mags) I do know for a fact and REGARDLESS what brand of a Magneto, THAT AT SLOW CRANKING SPEEDS THE ROTORS MAGNET DONT PASS BY THE COIL NEAR FAST ENOUGH TO INDUCE SUFFICIENT VOLTAGE INTO THE COILS PRIMARY Sooooooooooooo thats how n why when you turn the mag slowlyyyyyyyyyy its not initially turnign the rotor, but it turns to wind a spring that winds up n then releases to rapidly whirllllllll the rotor at a fast speed past the coil so it does go fast enough to create a good spark. A battery powered coil ignition uses battery energy n voltage to power up the coil while a Magneto creates its own energy by passing a magnet (rotor) past a coil of wire (the coils primary) to induce voltage and the faster the magnet passes by the coil the greater the voltage BUTTTTTT at real slow passes, theres not enough voltage induced, THEREFORE it needs to wund a spring up n trip it to rapidly whirl the magnet past the coil while its being slow RPM started. I hope some of the good gentlemen familiar with the Farmall mags will weigh in here to show me right or wrong, but until then "Thats my story n Im stickin to it" lol Thanks JT, best wishes n God Bless yourself and all else here. Hopefully we can all learn from this fun discussion, thats why were all here and I can learn about farmall mags if they are indeed different concerning how their spring assembly works if its different then the Mags Im familiar with??????????? John T, retired electrical engineer
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
