Re: 12 volt vs 6 volts
Posted by John T on November 28, 2005 at 12:43:01 from (66.244.90.98):
In Reply to: 12 volt vs 6 volts posted by Kurt in Va Beach on November 28, 2005 at 12:29:39:
Kurt, if its only a lil Cub you need to start, I see no advantage on butchering things up to convert it to 12 volts. Now on a bigger tractor it can be an advantage to help them start in extreme cold temperatures, but with a good battery and big battery cables a lil Cub ought to start unless its totally worn out and needs major work and tune up etc.
John T
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
