Re: 8v Follow up.....
Posted by Janicholson on November 28, 2005 at 12:57:51 from (199.17.6.175):
In Reply to: 8v Follow up..... posted by Dellbertt on November 28, 2005 at 09:28:45:
The impulse coupling on IH mags work the same as on other equipment. (as John T indicates) there is a spring wound speed increaser in the magnet.
JimN
