Re: Block Heaters.....
Posted by Janicholson on November 28, 2005 at 13:08:43 from (199.17.6.175):
In Reply to: Block Heaters..... posted by Dellbertt on November 28, 2005 at 12:45:25:
I like the in the block heater. It replaces a Core plug (often mistakenly refered to as a freeze plug, they allow the foundry to remove core sand after the casting hardens). They are tidy in installation, and work directly. It is necessary to put it into a hole that has room behind it. (I'm not sure what core hole on a 340 is used)
JimN
