Re: broken oil filler cap stud-- common problem? (
Posted by Janicholson on November 28, 2005 at 14:08:37 from (199.17.6.175):
In Reply to: Re: broken oil filler cap stud-- common problem? ( posted by Nebraska Cowman on November 27, 2005 at 16:44:31:
Use cloth rags stuffed into the hole in a way that blocks stuff from going into the engine, but so as to be able to get it out. Spray clean the area with Electro-motive, or Brake Kleen spray. Find a threaded insert (used in wood working, and plastics industry) with (I think 5/16" corse) threads. Use a drill that is just bigger than the insert, and drill out the area where the stud was located. Use some side motion to score up the drilled hole to make the repair stick better, and do not go too deep. Clean out the junk, and remove rags carefully to prevent getting them into the engine. Put the original stud (after cleaning) into the insert, and use Locktight thread repair epoxy to cement the insert into the hole. Screw the lid on just so as to square it up flat. Do not tighten. Let cure for 24 hrs if warm, heat it to 70 degrees with a heat lamp if it is cold. Then never tighten it like it was going to take a wrench to get it off. Good luck. JimN
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
