Re: 12 volt vs 6 volts
Posted by john d on November 28, 2005 at 15:50:28 from (69.128.202.146):
In Reply to: 12 volt vs 6 volts posted by Kurt in Va Beach on November 28, 2005 at 12:29:39:
I don't think there would likely be any advantage on a cub. On a bigger tractor that's been tinkered with to include high compression and oversize pistons, 12 volts may be needed to crank them under some conditions. 6 volts will start a stock antique tractor if the wiring, starter, connections, and ignition system are well maintained.
