Re: Block Heaters.....
Posted by Jimer on November 28, 2005 at 15:55:28 from (206.145.179.196):
In Reply to: Block Heaters..... posted by Dellbertt on November 28, 2005 at 12:45:25:
I have a 300u and was facing the same problem you have, what kind of heater? I could not find any "core plugs" in the block, found it next to impossible to put a lower radiator hose heater in it (no room, in fact tried but ended up with about 1" of space for the heater) so I ended up buying a 300 watt magnetic heater. Of the people around here I have asked, they work, but not like heating the water.
