D-282 tank heater installation
Posted by jd jim A on November 28, 2005 at 16:42:22 from (24.180.146.111):
I want to install a tank heater on my 560 diesel. I plan to run a hose from the block drain hole on the right side of the engine to the tank heater. Question is, this hole is only 1/4" pipe thread, most block drain holes are 3/8" pipe. Will the 1/4" hole allow enough coolant flow to supply the heater? Question #2- Where on the engine do I install the hose coming out of the heater? Most go into a tee installed in the temp sender fitting in the head, but if memory serves, 282 temp sender screws into the block.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
