Re: Sea Foam
Posted by old bones on November 28, 2005 at 17:50:12 from (207.177.106.83):
In Reply to: Sea Foam posted by PAULIH300 on November 28, 2005 at 13:55:15:
been using it for years. have not put it in crankcase, i always put some in gas tank, especially late fall when putting away for winter. i put it in every gas engine i have. i put some in the tank, run it for awhile to make sure it gets thru to the carb, shut it off. come spring, they (tractors, mowers, tiller, transfer pump, weed-eater, etc) always start right up and run great all year. wouldn't be without it.
