Re: farmall c with water in oil
Posted by Peabody on November 28, 2005 at 18:56:07 from (64.12.117.13):
In Reply to: farmall c with water in oil posted by farmallbo on November 28, 2005 at 14:07:56:
Before you get all excited about pulling pistons and sleeves and such, I believe I would pull the head first and see if you see signs of leakage across the head gasket. Much easier fix if that is so, or it could be a cracked block, or leaky sleeve(s), as said. Anyway, either a new head gasket with copper spray on both sides and properly torqued down and/or some Barr's "Stop Leak" might do the trick, before tackling a sleeve job.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
