Re: gear oil
Posted by Dave BN on November 28, 2005 at 20:39:03 from (152.163.101.13):
In Reply to: gear oil posted by joe/mass on November 28, 2005 at 16:46:45:
Yea, 85W/90. Be sure to change the fluid in the final drives also. You'll need a new gasket for each side when you do this. If you have a belt pully, that gets changed and filled seperately. Look under the belt pully housing and you'll see a small pipe plug to drain it. The recessed plug on top is to fill it. Dave.
