Re: H-Farmall with no power
Posted by old on November 29, 2005 at 11:17:17 from (207.69.137.39):
In Reply to: H-Farmall with no power posted by Jarvis on November 29, 2005 at 07:28:10:
Did it sit any lengh of time with out running?? Have you checked compression?? Sounds like it may have stuck rings and low compression. Put about a 1/4 cup tranny fluid in each cylinder and let it sit a day or 2 and then try to start it. Don't worry about the tranny fluid it will burn off fast plus moet of it will be in the pan by then. It will smoke badly but it also might run a lot better. I have a little crawler that had only about 50-60 psu on each cylinder and after doing the tranny fluid the compression went up to 90-100 per cylinder and has stay that way.
