Re: Farmall 300 still weak spark ???
Posted by jetman on November 29, 2005 at 12:22:56 from (12.146.240.34):
In Reply to: Farmall 300 still weak spark ??? posted by railroadgoat on November 29, 2005 at 09:43:20:
If you are measuring the spark from the coil and it is weak, I'd say the insulator where the wire goes through the distributor is bad.
Remove the wire from the points/condenser and the coil to distributor wire. Put the coil to distributor wire on the points and try the finger opening and closing the points test. If you get a good spark you will need to remove the insulator and clean it with electronic cleaner. Make sure it isn't cracked and reinstall or replace. Reassemble and it should go.
