Re: H-Farmall with no power
Posted by Theman on November 29, 2005 at 12:43:43 from (65.248.77.5):
In Reply to: H-Farmall with no power posted by Jarvis on November 29, 2005 at 07:28:10:
It could be that your ignition timing is a bit late or the mechanical advance in the distributor isn't working. Check this with a timing light. If your H is still on a 6-volt system, you will have to hook the power clips to a 12-volt battery. One other thing to double check is the proper point gap. It should be 0.020" unless you have a mag (0.013")
