Re: W9D all cylinders stuck
Posted by El Toro on November 29, 2005 at 14:17:22 from (205.188.117.73):
In Reply to: W9D all cylinders stuck posted by Wheaty on November 29, 2005 at 14:06:22:
I used transmission fluid for soaking. Once you remove the pistons you can then clean the sleeves
and check for wear & any pits. I used a piece of 2X2 oak and drove them out after it soaked for a week or so. Some of the men have used Coke. Just need to be patient too. Hal
