Re: Farmall 300 still weak spark ???
Posted by Hermit on November 29, 2005 at 16:21:48 from (69.21.48.101):
In Reply to: Farmall 300 still weak spark ??? posted by railroadgoat on November 29, 2005 at 09:43:20:
Here's a couple of things I haven't seen discussed yet. Check the ground cable from the battery to the tractor frame grounding point for dirt, oil, corrosion, broken or chafed wires, etc. Also, you said you hot wired the battery side of the coil and had the same problem. Why not try to hot wire the distributor side of the coil, too. That way you can eliminate or isolate the distributor components of the ignition system. Just disconnect the wire going to the points install a length of wire stripped at each end. Place the coil wire 1/4 inch from the block and then repeatedly touch the installed wire end to a bare ground, acting like a set of points. Good luck.
