Re: STEERING PUMP FOR HITCH
Posted by Ron Penrod on November 30, 2005 at 07:14:50 from (207.255.30.138):
In Reply to: STEERING PUMP FOR HITCH posted by CARLOSGENARO on November 29, 2005 at 23:22:10:
I installed a chevy p/s pump on a farmall H that I built a 3 point hitch for. It lifts a 2 bottom plow with no problem. I installed a 2 way control. An with a scraper blade on it will lift the rear of the tractor off the ground. I would recommend a pump from a older pontiac it has a higher flow rate.
