Re: Farmall 300 still weak spark ???
Posted by Rider on November 30, 2005 at 09:42:42 from (66.77.159.132):
In Reply to: Re: Farmall 300 still weak spark ??? posted by old on November 29, 2005 at 11:23:03:
One thing that has not been mentioned, have you cleaned the coil inside the mounting bracket and the bracket to block mounts? Also check the distributor ground (housing to block). It looks to me that all the testing you have done is upstream of the points. Any high resistance in the circuit supply or ground side will give the same result. I would try a wire from the point locking screw to a good ground on the block.
Good luck,
Walt
