Re: Maybe my first Farmall
Posted by Ron in Nebr on November 30, 2005 at 10:55:57 from (12.192.38.23):
In Reply to: Maybe my first Farmall posted by famousfather on November 29, 2005 at 22:23:01:
Another thing I don't think has been mentioned is to check for excessive wear in the pivot pins of the loader- where the main arms pivot, where the bucket attaches, etc.
If you lower the loader to the ground and give it slight down pressure, then raise it up again, you should be able to see if there's any movement at these pivots. It's gonna have some no doubt, just watch out for anything that looks "excessive". On some loaders these pins are easily replaceable when they get worn, on some types you're looking at alot of work to rebush and repair the pivot holes and pins.
Be sure to try the tractor in all the gears, make sure the pto works, etc.
Good luck!
