Re: Farmall 300 still weak spark ???
Posted by El Toro on November 30, 2005 at 13:08:27 from (205.188.117.73):
In Reply to: Farmall 300 still weak spark ??? posted by railroadgoat on November 29, 2005 at 09:43:20:
Since the engine on this tractor just up & quit
it may have jumped time somehow. If you bring No1 piston up on the compression stroke to TDC & then check to see if both valves are closed on No1 cylinder & the rotor points to No1 plug position in the distributor. This would eleminate the valve timing & the distributor being out of time. Hal
