12 Volt Alt. Conversion - - Plumbing Question
Posted by Farmall_Ryan on November 30, 2005 at 19:57:19 from (128.153.220.71):
If I convert my M to 12 volt and decide to use an oil pressure switch on the alternator cut-out, how do I go about plumbing that in? The reason I ask is because its a mag ignition with the push pull ground out switch. I'd like to keep that rather than adding a toggle switch, but I want the alternator cut-out to be automatic. Using oil pressure is the only automatic way I can think of doing it with a mag ignition...
