Re: O.T. Ford Ranger
Posted by Buzz on December 01, 2005 at 15:47:02 from (65.143.124.170):
In Reply to: Re: O.T. Ford Ranger posted by Janicholson on December 01, 2005 at 15:20:27:
Jim,
Yea, I agree on all that. Thing is, is that it leaks SO much that I don't need any leak detector!!! Holy molie that thing pukes out of there.
I cleaned that area off before I pulled the tranny and all I could see was oil coming from the drivers side corner of the engine. Actually in that head gasket area and down the bell housing mounting flange of the tranny.
Funny thing just hit me as I write this---oil most generally leaks and goes downward, thanks to gravity. My guess is that the head gasket is leaking. Oil travels down onto the bell housing and follows around and down on the floor.
Just kind of strange to me that a head gasket would do this---wonder if this is common on this engine after a few years and miles.
Buzz
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
