Farmall Tractors Discussion Board
Re: Slipping road gear in MD...
Posted by Phil Auten on January 01, 2000 at 07:25:56 from (206.175.72.226):
In Reply to: Slipping road gear in MD... posted by Baggsy on December 31, 1999 at 21:16:55:
Baggsy,
Probably just a bent shift fork and the gears aren't meshing fully. If the fork is bent it can be straightened or replaced (straightening's easier). If the fork isn't bent then the gears are worn and will have to be replaced or just don't use road gear (that's the easiest and cheapest fix of all).
Phil
Post A Followup
: Re: Re: Slipping road gear in MD...
