pump update
Posted by fenton on December 02, 2005 at 11:52:07 from (128.253.9.82):
Well....got the rebuild kit from IH. Took the pump to them and they looked at it. They thought a new o-ring seal will work on the shaft as the wear was not too bad. They said to smooth it out a bit with emory cloth. Got it back together and so far so good. The sleeve on the shaft fix was not to their liking and said the clearence is too tight between the shaft and the hole it goes in and machining is very costly??? Their words. Now...the only replacement pump they show is around $600....YIKES!!! I am sure some where there are cheaper ways if the pump fails again. I'm not using it much, so I hope it holds.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
